iR C3220N always show printing is warming up...
  • sgcopiertech
    Machine never stops warming up...
    After boot up...it will just show warming up
    and you would also hear the mechanical parts
    moving.
    checked the fixing and it is already set at
    189'c - 192'c and stays around there.
    start button is red.
    so far i have changed the fixing unit
    but still shows the same problem.
    any ideas? thanks alot!
  • ricardobres
    • 147
    Replace the drum unit. It must be near the end of life. (*28* copier - misc), you can see the drum unit "life".The normal value is below 150, may reach more. If the valueif the value is well above 250, can be this unit the problem.
    • sgcopiertech
      why is the drum unit related to the warm up time?
      doesn't it give its own error code when it is already out of service?
      • ricardobres
        • 147
        Because the machine is trying to adjust the print quality, and don't get. Most times it's an error code, but other times it's this defect. I already had this defect in one of my machines.
        • cdtw9803
          • Aug 2009
          • 51
          drums are out of life or cleaning blade of ITB doesn't work well.
          • sgcopiertech
            thanks to all! it was the black drum unit
            • Van Steal
              • 177
              You may also have a problem with your black toner bottle. have seen this a few times and it was caused by toner not being added to the drum. you can check which one is the fault under DENS in service mode you will see it 4 or 5%
              • waffu22
                • Jun 2009
                • 95
                its just something the same problem of mine. i got an iR5000 (220V), the problem is when printing its always show a "warming up". it takes 30 seconds.
                any ideas how to resolve it?
                thanks
