IR5000 how use pcl to print barcode?
  • rangelmp
    Hi. IR5000 have a lot of barcode fonts, i can use all fonts with PCL but i can't read the barcode with the reader.
    I'm using this PCL code to 128c barcode.
    ESCAPE(19Y
    ESCAPE(s1p20v4s3b0T
    46090703918549000132550030006172982619562376
    Line 1, 2 select the font
    lLine 3 bar code value
    In IR50000 i have to put START C and STOP code? what is START and STOP char code in IR5000? I need to calculete the check char?
    So how is the correct use for this font?
    Where in the role world are the font reference guide?
    Thanks.
  • SCREWTAPE
    The bar code fonts supported by the imageRUNNER-iR series:
    BC 3 of 9 Thin
    BC 3 of 9 Light
    BC 3 of 9
    BC 3 of 9 Semi
    BC 3 of 9 Heavy
    Code 128
    Code 128 Bold
    Code 128 Condensed
    Code 128 Condensed Bold
    Code 128 Expanded
    Code 128 Expanded Bold
    Interleaved 2 of 5 Light
    Interleaved 2 of 5
    Interleaved 2 of 5 Semi
    Interleaved 2 of 5 Bold
    Interleaved 2 of 5 Narrow Light
    Interleaved 2 of 5 Narrow Semi
    Interleaved 2 of 5 Narrow Bold
    UPC/EAN
    UPC/EAN Bold
    UPC/EAN Condensed
    UPC/EAN Condensed Bold
    UPC/EAN Expanded
    UPC/EAN Expanded Bold
    CodaBar
    CodaBar Condensed
    CodaBar Expanded
    MSI/Plessey
    PostNet
    To print out the complete PCL font list:
    Method 1:
    Press Additional Functions, Printer Settings, Utility, PCL/PS, PCL, Font List, and select Yes.
    Method 2:
    Press Additional Functions, Report Settings, Printer, PCL, Font List, and Select Yes.
    • rangelmp
      Thanks, i know the bar code fonts supported by their5000, i use all and i can print everthing ok.
      But i can read the code bar.
      • rangelmp
        up...
        Someone know who use the barcode (code128) fonts on IR5000?
        I try:
        Code:
        ESCAPE(19Y
        ESCAPE(s1p20v4s3b0T
        But i can't reader this barcode. What i miss? Start, stop char? Balnk char?
        Thanks.
