so i've having trouble figuring out the proper way to setup scan to email, I'm attempting to use a gmail account. i've tried setting it up with the listed pop and smtp servers but could could find where to set the ports on the copier, needless to say it didn't work, so then i tried pinging the pop and smtp servers and using " : " and the port number to get it to connect to the proper port, but that didn't work either.
Does it have to use standard port settings or is there a way to change it?
Better yet, what is the proper way to setup scan to email?
In the last three years this is maybe the second time a customer has wanted to use this function.
Thanks in advance!
Thanks in advance!
