Canon ir c3200 can't change ip settings
  • dbd1616
    • Aug 2025
    I'm trying to change the Ip address on our Canon ir c3200 and there are no fields for the ip address under TCP/IP settings on the copier or the web interface. Unfortunately, the manual is missing. I have accessed these settings on other canons on our network without any problems.
    Any help would be greatly appreciated.
    Thanks.
    Darren
  • nivssluck
    • May 2008
    • 228
    If you have Fiery printer you must change your Interface to 3. And if you're using internal board printer change your Interface value to 0 ( Additional Function 2&8 Additional Function, Copier, Option then Interface.
    • JustManuals
      • Jan 2006
      • 9838
      Call a qualified technician before you muck it up good!
      • dbd1616
        Originally posted by marc.lucas
        On the main screen you should have a "Printer" tab press that & you can then enter setup & change the IP address etc. Hope this helps.
        Thanks marc.lucas. That's what I needed to know. I got the ip changed.
        Darren
