iR6020 & iR6020i difference
  • Blues Guy
    • Aug 2009
    • 216
    Hi guys just get some info what is the different between these 2 model iR6020 & iR6020i. Can I upgrade iR6020 to iR6020i or downgrade from iR6020i to iR6020 ?
    What's is the requirement to do so ? Any comment is much appreciated
  • SCREWTAPE
    • Mar 2025
    Mostly (i) models come standard with printing and sending capabilities and meap, others that are not (i) models are just stand alone copiers. As far as downgrading from 6020i to a 6020 would be senseless, you can upgrade a 6020 to have these capabilities but it would not be considered a (i) model.
    • Blues Guy
      • Aug 2009
      • 216
      Hi Screwtape thank you for responding to my topic.
      How do you upgrade from iR6020 to iR6020i ? What are the requirement to upgrade these ? Do I just need to slot in the U SEND card which mounted in the main controller.
      Any other software need to upgrade ?
      • SCREWTAPE
        • Mar 2025
        It really does not matter.The machine can be upgraded buy purchasing the hardware. The(i) model is just another way canon markets the machine that all.
        • Blues Guy
          • Aug 2009
          • 216
          Good day Screwtape can u specified what are the hardware to purchase in order to upgrade the machine to ( i )
          I have few units of these iR6020 I wonder I can upgrade it and can sell a good price.
          Your advice in this matter is much appreciated.
          • nivssluck
            • May 2008
            • 228
            iR5020/5020i and ir6020/6020i has the system software...I did try it 3 times already...But it takes 45 minutes to 1 hour loading the system.
            • nivssluck
              • May 2008
              • 228
              iR5020/5020i and ir6020/6020i has the same system software...I did try it 3 times already...But it takes 45 minutes to 1 hour loading the system.
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                Can you specified what are the hardware to purchase in order to upgrade the machine to ( i ).
                As Screwtape has alluded to, the copier cannot be upgraded to an "i", that is merely a marketing deal for Canon to put all the things needed into the copier to accomplish the Print/Send/Meap capabilities. You can upgrade a 6020 to do all the things that the 6020i can do, but it will never be an 6020i.
                Network bootrom as well as a network card need to be installed in the 6020, then update system software to the latest network version. I believe that Universal Send needs also to be installed for the send portion to work, Screwtape can confirm yes or no on this.
                You then have a fully functional machine, just no "i" on the front cover.
                • SCREWTAPE
                  • Mar 2025
                  Confirm..
                  Couldn't say it better!
                  I also believe that you need a resolution switching board for the send feature.
                  • Blues Guy
                    • Aug 2009
                    • 216
                    Thank you guys for the information. I will try out one of these day and keep you guys update..
