Ir 2270 close finsher cover.
  • smiley
    • Aug 2008
    • 616
    there is no glory without sacrifice
  • cdtw9803
    • Aug 2009
    • 51
    maybe the acc power supply pcb in mainbody error,or finisher mainboard error. acc power supply pcb :fk2-0338-000 120v,fk2-0339-000,230v.
    • smiley
      • Aug 2008
      • 616
      Thnks for reply man.I lookng forward to the finisher main board.Cause it work grate when the finisher is not connected.I want to chnge it to tray.Cause the finisher main board is not available.Thanks man.
      • nivssluck
        • May 2008
        • 228
        I have finisher main board if you want..
        • SCREWTAPE
          • May 2025
          Smiley, which finisher are you talking about, S1, Q3,Q4?
          • smiley
            • Aug 2008
            • 616
            hi screw tape im using s1.now i change the main board of finisher but it still there then i check the acc board and i fund out that one of the resistor is open change it and bingo!!thank you all guys sorry for the late update.cause i wass been kick out from my previos imployer but luckily i got a job again.cheers guys
