Error code e00024
  • sudani19
    • Jun 2009
    • 27
    Error code e00024
    hi
    Ihave aproblem with CANON IR3035 , it gives an error code E000024-0000
    Hopper assembly was eplaced recently
    any solutions pls
    thanx
  • del286
    E024 The developing assembly connector is disconnected.
    0000 The connection detection signal is
    absent continuously for 100 msec.
    Replace the developing assembly
    toner sensor. Connect the
    connector. Replace the DC
    controller PCB.
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      WARNING...!!!!!!
      Make sure that you have power OFF when you plug in the dev assembly or you'll blow FU3 on the DC Controller board..!!!!!
