CLC1000 Error code E220
+ More Options
Posts
  • ricardobres
    • 147
    I have a clc1000 with error code e220. The machine was stopped 2 months, and when i turn on the machine, this error code appear. I checked the lamp, fuser lamp, and nothing.
  • BLITZKREAGG
    CLC 1000
    Title : E044 E220 not found in revison 0 or 1 of the service manual. Error :
    E044 and E220 were introduced with R-con ver. 6 and D-con ver. 5 for the CLC 1000, the information can be found in technical publication 1000-9 (10-21-97 ) and CLC1000/2400/3100-T026.
    Workaround :
    E044 0001 ( Multifeeder paper width setting error )
    E044 0002 ( Upper cassette paper width setting error )
    E044 0003 ( Lower cassette paper width setting error )
    E220 Scanning lamp operates incorrectly
    Lamp regulator PCB failure. During standby, even when the Reader controller PCB turns the signal for the scanning lamp OFF, the scanning lamps turns ON.
    Reader controller PCB failure. During standby, even when the Reader controller PCB turns the signal for the scanning lamp ON, the scanning lamps turns OFF
    E220 When scanning from the network. See Technical publication CLC1000/2400/3100. For EPROM update.
    The part number for the latest Service manual that includes these error codes and many other updates is FY8-13E3-020.
    • ricardobres
      • 147
      Sure, the error code is E000-220.
      • ricardobres
        • 147
        Thanks, I fixed the machine. I replaced the thermistor.
