IR 6570 Error Code E227-002
  • ricardobres
    • 147
    I checked and replaced the power supply, and the problem persist. I Have other machine to charge parts for test. What can I charge to test
  • BLITZKREAGG
    IR 6570
    Error :
    Problem was intermittent E227 previous technician had replaced the laser.
    Workaround :
    Solution:
    1. Remove the primary fan duct assembly (this assembly has a pin on it that activates the laser shutter)
    2. Remove and reinstall the laser assembly.
    3. Install the primary fan duct assembly. (The linkage was pinched not allowing the laser shutter to be fully actuated on the initial replacement)
    Finally a DC con clear resolved both of the intermittent issues.
    • ricardobres
      • 147
      • nardinard
        • Oct 2014
        • 12
        Re: IR 6570 Error Code E227-002
        hi. did u have fix this error?
