canon ir 3300 zebra pattern
  • jayrgs
    • Aug 2009
    • 5
    pls help. my canon ir3300 produces a zebra pattern in every copy. .
    I'm using a step down transformer 110v, 1500w and 60 Hz. it worked fine before..
    the charge roller have uneven toner coating...
  • davidj7
    • 1107
    does the charge roller un even coating matches the zebra stripes in print?
    a machine is only as good as your tech : source:screwtape ; the scary one
    • SCREWTAPE
      • Aug 2025
      Check your developer also.
      • etsmultan
        • Apr 2007
        • 131
        Change the charging roller,check charging roller voltage,if it nt ok then change or repair the tc board
        • cdvidaceiba
          • 80
          check spacer rollers in the developer roller they are maybe broken
          • jayrgs
            • Aug 2009
            • 5
            yes the uneven coating matches the zebra pattern. but when I turn the roller manually, the coating is even..
            And 1 thing i just saw a loose belt that is attached to the gear for the roller i think.. i can't see it clearly because its behind the body frame of the copier..
            tnx to your replies...
            • davidj7
              • 1107
              replace charge roller on which the uneven coating exists with a new one
              • bineeshgeorge
                • Jul 2009
                • 107
                Did you replace your drum ?
                • sgcopiertech
                  kabayan, are you using original canon toner? zebra pattern is sometimes related with mixing canon and non-canon toner.
                  • jayrgs
                    • Aug 2009
                    • 5
                    i did not replace the drum but its getting worn out already...
                    kabayan, the toner is original... are you a technician? can u service my copier? i need it badly.. (09053822404)
                    tnx.........
                    • jayrgs
                      • Aug 2009
                      • 5
                      problem solved.
                      its the drum. we replaced it and its good as new again.
                      tnx everyone
