New problem i have not seen, Went out to replace drum unit the same same way i have done 20 times before when i reinstalled toner cartridge the copier makes a growling binding sound and the copies are very light on the rear almost blank, when i remove the toner, copier works great. Machine only has 35000 prints. anyone experience this problem before.. Thanks
IR 1023 if niose with toner cartridge
New problem i have not seen, Went out to replace drum unit the same same way i have done 20 times before when i reinstalled toner cartridge the copier makes a growling binding sound and the copies are very light on the rear almost blank, when i remove the toner, copier works great. Machine only has 35000 prints. anyone experience this problem before.. Thanks"Once a King, always a King, but once a Knight is enough!"
binding noise
Yes i did reinstall old drum and noise is the same, no noise when toner removed, also did try another toner cartridge. same thing, before i replaced anything i let the customer finish a print job other than drum marks on pages copier was working great....thanks for feedback.Comment
