Canon IR 3235 network printing issues
  • mikibu
    • Jun 2025
    Hello everybody
    I want to setup an IR3235 in my office
    I'm n00b in copiers ...
    I was able to install scanning over network without problems :
    iR got an IP on the network, I can Ping it, and I can "push" scans to my PC with Color Network ScanGear
    BUT I'm freeze on printing !!!
    PC win XP SP3
    I have tried PLC, UDF and PS drivers... no way !!!
    My printing datas stay blocked on the PC
    Anyone can help ?
    Best Regards
    Miki
  • Walestech
    • Aug 2009
    • 16
    Does it have a print boot rom? Is it a 3025 or 3025i? Only the i models have a print rom as standard.
    • bnmand
      • Sep 2008
      • 383
      Also if it does have a print boot rom, can you try printing using a laptop hooked up via crossover cable to the copier?
      • mikibu
        Hi Masters, thanks for reply !
        even direct printing with crossover cable does not work
        It's an 3235 not a 3235i
        As i understand printing capacity is an option ...
        On 3235, how do you check if the print boot rom option is installed ?
        • bnmand
          • Sep 2008
          • 383
          Go into service mode and check the version of the Boot-Rom. Should also check to see that firmware for printing e.g. PS/PCL is installed as well.
          You'll need a tech to bring a print boot rom, install it and update the firmware using SST if you want to get printing to work if you don't have the boot-rom and/or the necessary firmware installed on the copier. So you'll need to decide whether this is worth the cost.
          • mikibu
            bnmand, many thanks
            I have a tramp in service mode
            copier _ display _ version _ BOOTROM = 01.20
            copier _ display _ version _ SYSTEM = 01.55 02.35 10.09 00.25
            copier _ display _ version _ ROOT = 01.28
            copier _ display _ ACC-STS _ PS/PCL = 0
            Can I hope print with this ?
            • Walestech
              • Aug 2009
              • 16
              If you press the "123" key for the counters, then hit device configuration. You should see UFR and PCL in the options, if not you need a print kit - this is a MEAP application.
              • SCREWTAPE
                • Jun 2025
                You should be using a UFR driver rather PS, PCL. Ufr is the standard driver, unless you require post script or PCl printing you need extra accessories to do so.
                There's is no bootrom require because the program is activated with LMS.
                • alex@wocltd.com
                  • 430
                  architect of the board also now using sata hdd
                  • mikibu
                    No UFR option
                    No PCL option
                    You should be using a UFR driver .....There's is no bootrom require because the program is activated with LMS
                    I'm using UFR II drivers - > ok
                    So I need to activate a software option using MEAP & LMS ?
                    If I'm right, can you tell me more about the procedure ?
                    I'm totaly new with this machine... I'm the final user
                    With Best Regards and Many Thanks
                    • SCREWTAPE
                      • Jun 2025
                      Originally posted by mikibu
                      No UFR option
                      No PCL option
                      I'm totally new with this machine... I'm the final user
                      If printing is the only thing that your concern about, forget about meap in this situation. All you need to do is get the printer kit, its a certificate, go to a canon website and get the license and activated. You must purchase the kit from a canon authorized dealer or from canon. Get yourself a quote price.
                      • KarlS
                        This device is not BOOTROM-based
                        This device is not bootrom based.
                        Print options are license based.
                        Verify the device configuration in Counter Check
                        Otherwise this device only prints using the UFRII driver.
