IR1310 slow copier
  • ebtv258
    • Aug 2025
    IR1310 slow copier
    Hi,
    My copier is slower than normal....what could delay the delivery even for a single copy???
  • Dalamar
    • Oct 2006
    • 117
    Well its a 13 page per min machine, then figure for warm up time, and consider its first page out is 13 seconds. As longs as it copies properly (no jams/errors) it would seem to me that its just a slow machine.
    If it bothers you, not to sound rude, but maybe you should consider a faster copier.
    Notatechie - "I am trying, but I don't know how to go into Service Mode. If I just go in and press *then 2, than 8, then * it does not do anything."
    SCREWTAPE - "Try harder.."
    • roho
      • Mar 2009
      • 844
      maybe someone has changed paper settings. If set for heavy paper, it would run slower then you may be used to.
