3220 out of registration
  • Juelis
    • Aug 2009
    • 20
    The prints are coming out of record. Already changed belt, already calibrated the machine, already adjusted the laser, but nothing helped.
    Does anyone have a clue?
    Thanks!
  • SCREWTAPE
    When you change the belt, was it replaced with a new one?
    How did you adjust the lasers; what procedure?
    Two options more:
    1) Upgrade firmware,Dc-con and R-con.
    2) Replace Dc-con PCB
    • THUK
      • 195
      HI,have you tried clearing dc con then do a couple of auto grads,the life itb assy is 300k change whole assy then do dccon clear and 2 auto grads.
      • welshman
        Technical Support Manager
        • Oct 2007
        • 91
        also when you do dc con clear leave the door open as it wont clear the reg settings if you dont
        found this out for a canon trainer 6 mnths ago he did not think it mattered till he had a problem machine and i told him to leave door open when did dc con clear it worked after 3 calibrations then
        • SCREWTAPE
          Interesting.
          • Van Steal
            • 177
            don't forget to get a P Print from the printer as you will need to re-enter the settings for the dc-con
            • Juelis
              • Aug 2009
              • 20
              Solved.
              @SCREWTAPE
              I swapped for a new belt.
              "How did you adjust the laser, what procedure?"
              I printed the "P Print" then I was changing the values of the laser to go on record.
              __________________________________________________ ____________
              He had also trying to reset the dc con.
              And when did it also print the values! D;
              I solved the problem, but otherwise!
              First reseted the dc con (again), then did the calibration 3x
              was not 100% ... then I went into "Additional Functions>> Common Settings>> Text / Photo / Map>> I changed to" Text Priority "
              After that was very nice prints/copies.
              Thanks a lot for all the tips, and divide my experience with you.
              Thanks Men.
              \ o /
