IRC 3220 network problems
  • kleppen
    • Jul 2025
    Hi!
    I have just bought a IRC 3220N and have problemes setting it up. I am trying to connect it to my laptop. My Network skills are not much to brag about, so I need a step by step explenation.
    My laptop is connetcetd to Internet trhrough a wireless router. The router is placed to far away from the IRC3220.
    I would preciate help on this one!
  • THUK
    • Jul 2008
    • 195
    hi,can you get the ip add of router,if so set your laptop to same range and set the copier to same range-have you loaded driver.
    • kleppen
      I have loaded the driver, but it can't find the copier when I have connected it to the laptop. I have tried bothe regular network cable and a crossover. On theccrossover cable the lights where on on the socket, but not with the regular.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Originally posted by kleppen
        Hi! I have just bought a IRC 3220N and have problemes setting it up. I am trying to connect it to my laptop. My Network skills are not much to brag about, so I need a step by step explenation.
        Are you trying to physically connect it to your laptop, or to your wired network? What OS are you running on the laptop?
        in a nutshell...
        laptop, network settings, tcp/ip settings, dhcp off,
        address: 192.168.1.100
        subnet: 255.255.255.0
        on copier, additional functions, system settings, network settings, dhcp off, IP settings,
        address: 192.168.1.110
        turn copier off, then back on, wait a few minutes for the network port in the copier to become active.
        connect laptop to copier via crossover cable, or through an ethernet switch. on the laptop open your RUN command, and type cmd, hit enter, type ping_192.168.1.110 (_ denotes a space) hit enter.
        your laptop will ping the copier and report back whether it is successful or not.
        When it shows communication, open Internet Explorer, and type 192.168.1.110 into the address bar and hit enter. This should bring up the Remote User Interface.
        If you can do this, try loading the print driver, that you can download from Canon if you don't have it, (PCL5) and configure it to port 192.168.1.110.
        • kleppen
          Thank you very much!!
          I have now managed to connect my 3220! Again: Thanks for helping me out!
          • mrfixit51
            • Oct 2008
            • 1975
            That is good news...
            You are welcome, that is what we are here for.
            • kleppen
              I have one more question. This has nothing to do with the network, but with the driver.
              When using print function I can't choose staple when making a booklet. Even though I have the capability on the machine. Does this has to do with the driver?
              I tried to print out a set of business cards. I placed the specially made paper in the tray on the right side, but it jams all the time... What am I doing wrong?
              Have a nice day!
              • Iommanxman
                • Aug 2009
                • 180
                Check that the paper you are using is within spec for the machine. Also have you told the driver that it has a finisher? You need to do this from within printers, click on properties and check in device settings that the options have been added such as finisher and paper deck etc. Also with some setting finishing and duplex options become unavailable if you are using certain types of paper from the bypass. This is due to the limitation of the duplex unit. Bearing in mind you may be able to feed 220gm paper through the bypass but you can only duplex up to 104gm. Meaning that it will not let you duplex the copy or print if you select thick card in the bypass settings for example.
                • mrfixit51
                  • Oct 2008
                  • 1975
                  To follow up on what Iommanxman told you, in the driver properties under Device Settings, toward the bottom there is a button marked, Get Device Status. That button will force the PC to have a conversation with the copier, and upon successful completion of that, all the "toys" will now be available to the driver, such as finishers, paper decks, external trays, paper feed pedestals.
                  • Iommanxman
                    • Aug 2009
                    • 180
                    Thats great Mr.Fixit. Allthough I have had issues with this not working if the Canon driver assist thing is not installed. Do we know if it has to have this installed to work?
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      Yes, it does,,, it used to be part of the driver install,, at least if you used the Canon driver installer method as opposed to the Windows "add printer" method that only goes out and gets the .inf files and such. That is why I carry the Canon installer software around only.
                      • Iommanxman
                        • Aug 2009
                        • 180
                        Sweet. Thanks for the advice.
                        • forbes
                          I am installing an IRC 2620 When I push Get Device Status, the system can not find the bottom two accessory trays, and when I attempt to print using an A3 sheet from the bottom tray, I get a red flashing light.
                          What do I need to do to install the accessory trays?
                          W
