ir2200
  • bomberi
    • 107
    ir2200
    I thank all for help, i have ir2200 with e602 03 error, I change the hdd by hdd hitachi and i have e602 01 error I ve trying to config the sst v45.01 with parrallel cable i have system. When I begin some error appear like warning code 145, a time out has occured wait a while, then repeat the same operation.so I want help for you
  • binks24
    • Sep 2009
    • 14
    • kuby
      • Oct 2007
      • 1410
      If you don't do the upgrade step by step you will get errors. Also is the hard drive compatible will this machine?
      • bomberi
        • 107
        Thanks I have try to format with the sst (hd format) and also I have error, I think the way is not correct so if you have another way to format it tell me now.
        • SCREWTAPE
          • Aug 2025
          Are you putting the machine in download mode. Also are selecting the correct interface setting in SST bi-centronics.
          • bomberi
            • 107
            I 've putting the machine in download mode, I connect it with parralel cable, open my sst on pc clic connect and select model ir2200 when i clic i see the firmwares ( all, all hd, hd format, language, rui, system ...) when i select for exampl hd format to try to format the hdd i clic ok the error will appear.
            • THUK
              • Jul 2008
              • 195
              hi,what is the model number of the hitachi hdd.is it compatible.
              • SCREWTAPE
                • Aug 2025
                What version SST are you using. These machines work better with earlier versions, v3.21, v3.22, v3.35. Have you tried reinstalling SST?
                • nivssluck
                  • May 2008
                  • 228
                  If you do not know how to play with .ift file when formatting different kind of HDD you're unlucky.
                  • kings5586
                    • 23
                    Use earlier version sst 3.21,3.35 Use hawk cable parallel to usb Download 2-8 If copier is connected use 2200n if not 2200 Format hdd then system software,also i use part # wm2-5230-000 hdd.Stay with it.
                    • senthil
                      ir 4570
                      dear all,
                      i have armoda kit & cd.. i wanted to do the converstion from 3570 to 4570 ..
                      how to do it (meter counter ) ..
                      please advice me.
                      thanks
                      • SCREWTAPE
                        • Aug 2025
                        Originally posted by senthil
                        dear all,
                        i have armada kit & cd.. i wanted to do the conversion from 3570 to 4570 ..
                        please advice me.
                        thanks
                        Dude your all over the place.
                        Let me give you some advice. Its your second post and you are posting a thread in a Ir2200 post regarding a 3570 and you want to know how to tamper with the speed and meter count. Not a good way to start posting threads. We do not advocate fraud at copytechnet.
                        • andy21557
                          Help Desk Technician
                          • Jul 2009
                          • 62
                          sst
                          i dont think a standard parallel cable will not work .. a specially designed cable (Nethawk) is required
                          • andy21557
                            • Jul 2009
                            • 62
                            quote from bnmand
                            "For those who don't know. The Nethawk cable is the only usb-to-parallel cable that works with SST and is very useful with old Canon copiers such as the IR3300 which don't have fixed IP. The only alternative is a IEEE1284 aka bi-directional parallel cable. As most, if not all laptops do not have parallel ports any more, a nethawk cable is very useful for those working regularly on copiers like the IR3300."
                            • bomberi
                              • 107
                              HELLO I am back now i have try to format the disc and the error : is typ of hdd is not match please cheick your file (*ift ) hdd model hitachi dk23ca-20 I think that the hdd is not compatibl.
