Canon IR2200
  • Norma_D
    • Sep 2009
    • 10
    Canon IR2200
    One of my customers has a Canon IR2200 and the copies keep coming out light and faded. I've put in a new drum and that worked fine for a couple of days but they are still getting the light/faded copies. Can anyone help out on this?
    Norma
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    Did you run the DPC-Gamma after replacing the drum?Should have been a sheet in the box with the drum(if from Canon).
    • SCREWTAPE
      • Jul 2025
      Norma
      Replace the transfer roller.
      • Norma_D
        • Sep 2009
        • 10
        He told me that nothing was included in the box. Is there somewhere I can find the information w/o having to reorder a new drum unit? If not I guess I will have to.
        • Kopyrtek
          Copier Psychologist
          • Jan 2007
          • 407
          Once in service mode>copier>function>DPC>gamma.Press start.
          • Norma_D
            • Sep 2009
            • 10
            Thank you so much for the great information! I will be sending my tech back out to the customer this week and will let you know how it works out. Thanks Again!!
            • Brian8506
              • 1664
              I beleive you need to have paper in tray 2 for that procedure as that's where it draws it from.
              • bineeshgeorge
                • Jul 2009
                • 107
                You try all the above suggestions , yet the same problem exists, you check the toner. Fully clean the developper unit with the help of a vaccum cleaner / blower and add fresh toner then you check.
                good luck..........................
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  I'd be looking at the Dev unit,making sure that the contacts at the rear of the unit are nice and clean...
                  Turn the cylinder by hand and see what the coverage on the cylinder is like...any faded areas on the cylinder and you've found the culprit.
                  After market toner can cause this issue.
                  I've also seen faded copies come from a faulty DC Controller on the 2200's...rare but it happens.
                  And like Scewtape mentioned...sometimes either the bushings for the transfer roller collapse or the rubber coating of the roller goes hard and it needs to be replaced.
