Canon IRC3200 Error 751 - 0301
  • ilovetoner
    Can anyone explain to me what the error 751 - 0301 is on a Canon IRC 3200?
    I tried searching and found a 751-0302 but didn't know if it was the same or not.
    Thanks in advance.
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    Last number refers to the color.
    E751 can be displayed when a connection error of the drum unit or toner cartridge occurs. The following are the detail of each sub code. You may find it helpful to refer to them when servicing. The suffix "x" of each sub code shows color of the affected drum unit or toner cartridge. (1=Y, 2=M, 3=C, and 4=k)
    - 000x: Drum unit connection error (on printer side)
    - 100x: Toner cartridge connection error (on printer side)
    - 010x: Drum unit memory writing error
    - 110x: Toner cartridge memory writing error
    - 020x: Drum unit memory data error
    - 120x: Toner cartridge memory data error
    - 030x: Drum unit memory writing error (The number of reties exceeds the specified value.)
    - 130x: Toner cartridge memory writing error (The number of reties exceeds the specified value.)
    • ilovetoner
      thank you very much kopyrtek this will be very helpful in trying to troubleshoot this problem.
      • Kopyrtek
        Copier Psychologist
        • Jan 2007
        • 407
        Glad i could be of help.Please post what you find to fix this issue.
