9070 finisher lock ups
  • hachetman
    • Jul 2009
    • 96
    I have a 9070 with a K4 finisher, three times this month the finisher locked up no response from finisher and no erorr codes on the copier, popo ( power off power on) resets it I suspect the finisher control board
    has any body out there seen this before?
    Thankz Steve
    Steve Baker
    hachet1_12@outlook.com
  • SCREWTAPE
    • May 2025
    Thankz Steve
    If you try to make a copy does the machine go into suspended mode.
    Does the finisher seem like it has power when you come across this problem? Besides error codes are there other messages like "Finisher can't be used" or "Functions Limited".
    • hachetman
      • Jul 2009
      • 96
      Finisher has power, leds are on, I have seen both messages, copier will jam at copier exit leading into the finisher, no suspend mode, I removed finisher copier runs fine!
      Steve Baker
      • SCREWTAPE
        • May 2025
        What version is the finisher controller, I believe there up to v6.
        I would try the finisher controller pcb.
        • hachetman
          • Jul 2009
          • 96
          I have a Finisher control board on the way I can't remember what the version of software the finisher is we are trying to obtain software as we talk!
          I'll keep ya posted on the out come
          Steve Baker
