Marging problem in IR8070
  • abkonnet
    • Mar 2008
    • 166
    While Taking Copies in A4-R the upper margin goes near to the edge of the paper in the second side of the double side copying. I have attach photo to show that. what makes this problem? Its problem with the Scanning unit or with the Feeding unit? Pls help me.
  • Kapten
    • 52
    Margin setting
    From glass or ADF/ RDF.
    It seems that you are using the glass and book mode.
    If its from ADF / RDF the setting is made in the doc feed menu.
    Usually you have a sensor that will align the 2 side correct.
    If the sensor is ok then its an adjustment in servicemode.
    This parameter should solve the problem.
    Adjustment: COPIER> ADJUST> FEED-ADJ> ADJ-REFER
    If it dont solve the problem you might have an mechanical problem in the duplex area...
    Good luck
    • waffu22
      • Jun 2009
      • 95
      this problem is just the same problem of mine. i used iR5000 machine, when i copying from the glass using double-sided the upper margin goes near to the edge of a paper.
      Any suggestions please.
      Thanks.
      • abkonnet
        • Mar 2008
        • 166
        I just lower the value the problem is solved.
