E-586 0001
  • Kapten
    • 52
    E-586 0001
    Is there anyone outthere thas has a small idea..
    The manual says nothing.
    The code doesnt exist in it??
  • pengtech
    • 41
    what model are you referring to? But normally if the error code start from 500+, it mean that the finisher is having problem.
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Symptom
      E586-0001 on a Finisher-X1.
      Cause
      E586-0001 is a Stack Tray Unit failure. Safety Switch SW2 cuts off 24V to the Stack Tray Motor M2, if the switch is opened during operation. In a few cases, it has been found that SW2 is bent / out of place or the tension spring has come off.
      • hachetman
        • Jul 2009
        • 97
        maybe a trash can was under the trays when they were taveling down
        Steve Baker
        hachet1_12@outlook.com
