canon IR 200 code E031
  • sayednabil
    • Sep 2009
    • 72
    After finsihing the copy by stack bypass i am getting code E031.I am getting this code after reparing the IP board. i seen by replacing the DC board the problem remain the same E031.Help Needed indeed. thanks
  • SCREWTAPE
    • Aug 2025
    The Options Copy Counters CNT2 or CNT3 may not be operating correctly.
    • sayednabil
      • Sep 2009
      • 72
      well additional counter have been remove from machine.so wt to check ir now
      • gaurang_chaudhari
        This error is basically of counter open circuit
        so please check the jumper of counter
        • gaurang_chaudhari
          If u have removed addition counter then
          join it with help of jumper so the error may be corrected
          • infomaxbs
            Trouble Hunter
            • 29
            Y U steal D counter Put it back in the machine
            Failures is the knowledge bank of experiences
            • SCREWTAPE
              • Aug 2025
              Well the machine needs the counter. The error code pertains to those components,with out them you will just continue to get the E code.
              • sayednabil
                • Sep 2009
                • 72
                I have check the counter it working fine ,i think the problem is the supply after having the copy their is not properly supply going to dc board.
