How Network in IR600?
  • yuen
    Hello, I have a Canon IR600 copier, but can not find how to configure the network, could you tell me how to do it?
  • SCREWTAPE
    Do you have printer board in the machine?
    • yuen
      I don to much, but, in the back has a ethernet port, or sorry, what do you mind with printer board?, please helpme...
      • gaurang_chaudhari
        if u are connecting directly from pc u need cross connection cable
        if u using switch/hub then u have 2 use direct connection cable
        • Brian8506
          • 1665
          Check under version in display and see if you have an N bootrom. If you have a C you're gonna have to change it before you can network it.
          • ymmtech
            • Jun 2009
            • 190
            Common sence of ir3300 not apply to ir600. There is no such thing as C boot ROM for ir600.
            • Brian8506
              • 1665
              My mistake, I thought it said IR6000
