Ir 4570 film paper dryout???
Where is the problem????????
But my mechine once give 50 to 70k . Once 18 to 20k ..may be it tears 18k also. Once same film gives 50/70k copies..
Using and changing same film what is the diffrence???????
Where is the complaint??????????Comment
its with the quality of the filim . What kind of film are you using, Genuine Canon or OEM. As for your white grease part, try using fuser oil. I did try once with xerox dc 12 oil worked wonderfully but then I was in your shoes . My issue I finally concluded was quality of fixing film. Now i use only Genuine Canon, true its costly but like mrfixit said you have to achive and maintain a balance .a machine is only as good as your tech : source:screwtape ; the scary oneComment
Had the same problem. Replace the fixing film unit and the pressure roller(Black one) . The pressure roller is uneven causing uneven pressure on the film. This causes the film to tear in the same spot every time.
Good lucksigpic
Life is a Journey enjoy the ride !!!Comment
well, today i received a call from the same customer regarding the e007. again film teared and i can sure the floor level is even. fixing film assembly,pressure roller changed. the only thing come to mind is the frame itself, i remember the unit fell on ground when i am replacing the unit. i am really sure it's the frame deformed due to my mistake. now the only way is to order a new fixing assembly. if you are asking why i am so careless the answer would be the location. i know i shouldn't make excuses but at the customer place there aren't any table to use. so i worked on the floor with one hand holding the assembly.Comment
it's definitely the fixing unit frame, the fixing film i changed 2 weeks ago teared again. pressure roller changed and i remember the fixing assembly dropped on the ground during assembling. it's my mistake though. the deformed frame causing uneven pressure thus lead to film failure. the only solution now is to order a new fixing assembly. T_T (my boss gonna kill me!) let's keep this a secret between usComment
The paste that dries out is actualy heat transfer paste. It does dry out but shouldnt effect the function of your fixing unit. If you are getting an E007 this would meen that the film does not rotate at the right speed. If you are not getting an E007 their is something else is causing the jam. Try swiching paper to A4R/ltrR and make a copy. You must confirm that it is the fuser causing the jam. What jam codesigpic
That's not right paste...
the paste that dries out is actualy heat transfer paste. It does dry out but shouldnt effect the function of your fixing unit. If you are getting an e007 this would meen that the film does not rotate at the right speed. If you are not getting an e007 their is something else is causing the jam. Try swiching paper to a4r/ltrr and make a copy. You must confirm that it is the fuser causing the jam. What jam code
oh..
Whenever dry out paste.. Film paper cannot rotate such speed. Then paper cannot out it timingly.. When film paste dry out.. Paper jam inthe unit. Jam says paper jam in fixing unit..
I remove the fixing unit and rotate manually . It will very tightly roataing that to film cannot rotate. Pressure roller three times rotate film paper rotate one time. How it is????
Then ...
I can remove fixing unit remove film paper and removes dry out paste, ican apply new paste then fix as it is.
It can worked some more copies. Approx 5000 to 7000 copies.. After again jam start in the fixing unit. Like do as well as.
Main thing is here may apply the paste is not right paste..
Here suppliers are more greases selling. Each grease amount to says 300 to 500 rupees..
I can apply all type of greases/pastes. But all pastes are not worked properly......
What to do.......Comment
oh..
Then ...
What to do.......sigpic
I don't know that using heat transfer paste, like that used on cpu heatsinks, would be a good idea. While it has excellent thermal transfer properties, it's use is for stationary objects. Lubricity is another quality of the thermal grease used in the fixing film assemblies, and I can't imagine that the heat transfer paste has any of that quality accounted for...
It is this lack of lubricity that is stalling out the fixing films, causing jams and torn films..."Once a King, always a King, but once a Knight is enough!"
hi.. Thank you for reply gerhard...
O.k i am asking in electronic shop about heat sink paste. 4 months back. He says this is limited heat control. No way for control highest range of heat. So i canot take the pate. And forget also about that paste.
O.k you says its now again . Now i can buy the paste.
Whatever it may be when apply that paste. If the paste is success for dry out film . Half of the compalint is solved.
Wait and see for the result.
Any way thank you gerhard..Comment
Hi Gerhard,
I have used the paste in an Ir2270 and Ir3530 and have not had a come back (2 months). I improvise when needed Sometimes it works and some times not. Thanks for your comment
Regards
Gerhardsigpic
Seshu, I'm sorry but to me it looks like you don't want to take any advice. Parts go bad. Units go bad. Heat changes things. Taking a unit apart 7-8 times may stress parts. You act as though we should fix your problem. Its your problem.Comment
