I am having problems with color registration on a C3220. I do gradiation adjustment and colors may be 3mm or more off. I replaced ID sensors and ITB. I know with Ricohs I can adjust manually. I have a CD version of the manual but is shows almost nothing about this problem.
IR C3220
hi guys clean the rollers and gears of itb unit clean the inside surface of the belt.use citrus oil in cleaning in alcohol works but not to long.then do gradiation.if still there is a displacement after clean you have to do dc con clear.but you have to do the p-print.before dc con clear.gud luckthere is no glory without sacrificeComment
You know that saying if working don't touch. I have just been going around in circles with the same issue after removing ITB and cleaning it, something to think about to help you.
1. Remove the ITB cleaner, if it improves the alignment think about replacing belt and blade as a unit.
2. if after blade no improvement and the misalignment is consistant, then a DC clear is next.
I had forgotten all about the clear, untill I did a search on Friday. I remember it happening once before. Going to the customers this morning, i'll let you know how it goesCopiers are only as good as there last serviceComment
mycopier
service support & manual
I'm looking for Service Support tools & SST Software for iRC3200.
Plss...email to ezatek@gmail.comComment
sgcopiertech
re-arrange the laser units and then execute L-ADJ-O
this solve my color registration problem twice when servicing the ITB doesn't solve it.Comment
