iRC3220N show printer is warming up
  • nghialuuvn
    • Jan 2008
    • 67
    Hi All,
    I have a case of iRC3220N, now it always displays message"Printer is warming up" on status line and machine run continuously, non stop. I tried to make copy or print, the machine still receive job, data lamp flash and nothing print out. Who have experience in this please give me some advices.
  • SCREWTAPE
    • Jun 2025
    I believe somtimes this happens because of bad drums.
    • pengtech
      • 41
      check the error code, as screwtape mentioned bad drum, the error code will allow you to know which drum is bad.
      • pengtech
        • 41
        I mean check the error history. It will show E00020-xxxx, it will allow you to know which drum you need to change.
        • Kapten
          • 52
          Warming up
          Check the dens value.
          If one sticks out, you have find the problem cartridge.
          The value should be quite low 0-2 i think if its over that change cartridge.
          It could also be the toner cartridge drive assy.
          But i doubt that its the pcb.
          • nghialuuvn
            • Jan 2008
            • 67
            Hi All,
            Thanks for all your reply. This symptom happened after I replace 4 new drum units two weeks so I dont think reason from drum.
            Finally, I tried to clear MN-CON in menu FUNCTION>CLEAR and success.
            Too lucky!!!
            • dlucas
              • Oct 2009
              • 31
              even though the drum units are new but sometime it can be defective. i once encountered a irc3380i with e025-003. found in the manual was the hopper assembly problem. i replaced the feed screw sensor and pizero sensor but the problem persisted. lastly i replaced the new black drum which i changed few days ago and wala! fixed.....the problem was the drum catridge feed screw didn't rotate and caused the feed screw sensor to turn CCW.
