iRC3220 E110-0110
  • pga
    • Jul 2009
    • 67
    iRC3220 E110-0110
    Dear All,
    Good day. Anyone have ideas on this issue. I had changed LASER Unit, DC-Con't and put all part from problem m/c to working condition m/c and work fine.
    When switch On, m/c will show E110-0110 after awhile. Please advise on this issue.
  • Kapten
    • 52
    E 110
    I had this code for a few months ago.
    It could be 2 things (possibly more) byt try this.
    It could be the fuse pcb on the rear.
    I thing its in the lower part and in the middle.
    Or it could be a drum cartridge problem.
    Witch one is trial and error.
    I swopped the Fuse Pcb..
    God luck
    • SCREWTAPE
      • Sep 2025
      There are four lasers,which one did you change.
      Do you know what the sub-code 0110 refers to?
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        0110 = Yellow laser OR laser motor.
        But in this instance I'm with Kapten...look at the fuse pcb.
        • SCREWTAPE
          • Sep 2025
          Alright, now that we know which laser it is, I would had prefer if pga told us which laser he replaced since he did not mention which one it was that he changed.
          I would swapped the yellow laser with magenta just to do a process of elimination and see if the E code carries on, if you it does. You should see a -E110-0210.
          Also before searching for the fuse pcb check the voltage reading for the fuse pcb on the DC.
          • pga
            • Jul 2009
            • 67
            Dear all, i had changed Y laser unit, Dc-Fuse PCB, DC-cont but yet not solve.
            • SCREWTAPE
              • Sep 2025
              Check for pinch connectors, check pins, cut wire ties for yellow then.
              • Kapten
                • 52
