ir 200 code E100
  • sayednabil
    • Sep 2009
    • 72
    ir 200 code E100
    well i have open the laser unit for cleaning purpose after putting back the unit i am getting the code i have change the ccd cable after also i am getting the code E100 is there any solution..Help Needed indeed. thanks .
  • SCREWTAPE
    • Aug 2025
    E100 refers to the laser.
    • sayednabil
      • Sep 2009
      • 72
      How to solve this code any solution
      • Kapten
        • 52
        Take out the Laser and replace it properly
        If the laser is not installed properly the shutter could cause some problem.
        Poor contact from the Bd signal to the DC controller.
        What was the problem from the beginning?
        • sayednabil
          • Sep 2009
          • 72
          Image wasnt cuming proper
          • bojans
            • 1313
            You should open laser unit and check is every mirror on its place (maybe you moved some of them, when cleaning), and check shutter which opens/close laser. (it's small plastic that opens laser when you close/open front cover/left cover)
            I had this problem several times
            Good luck
