imagePRESS C1 & Fiery Server Q1 "please wait"
  • Stanman
    • Oct 2009
    • 24
    I am trying to get an imagePRESS C1 to work and keep getting the "please wait" when it should show "idle".
    Initially it went through the Fiery setup where I had to put in the password etc, now it just says
    "please wait" and when I put a monitor keyboard and mouse on Fiery it turns out the Fiery is not going into operating system, it just waits on logon screen for password.
    Once I log in if I print test page the imagePRESS C1 green light says processing but then it does not print.
    I do not have disc to restore os but I am wondering if that is the solution.
    Any suggestions appreciated.
  • pga
    • Jul 2009
    • 67
    you can try to clear DC-cont but b4 claer,print p-print 1st. i got faced it b4 and just clear dc-cont.
    1 more is Q1 server need re-install.
    • Kapten
      • 52
      A good idea is to
      A good idea is to reinstall the system.
      • Stanman
        • Oct 2009
        • 24
        Thanks for the reply, I do not have a disk for the system,
        do you know how I could get one?
        I have ftp, do you know if it would be possible to get an image file.
        • Stanman
          • Oct 2009
          • 24
          I am still needing the disk to restore the operating system and hope someone could help me out with this.
          I could PayPal postage etc if needed.
          • Stanman
            • Oct 2009
            • 24
            OK, I finally have the operating system disk/s on the way.
            Do I install from the drive in the Q1 or do I install from another computer through the
            crossover network cable?
            Will I be clearing and restoring the entire drive or just the partition with winXP?
            Any info appreciated.
            • Kapten
              • 52
              Use X over cabel
              Use X-over cable and deamontool.
              Then you don have to burn the sytem and you will save time.
              Good luck
              • Stanman
                • Oct 2009
                • 24
                Good luck
                Thanks for the info, Kapten, I see that deamon tool can be downloaded and wonder what it is and what it does.
                I am familliar with restoring hard disk or partitions from image files but have never restored
                using a X-over cable.
                Could someone explain it to me like i was a six-year-old?
                • CanoNiR
                  • 50
                  If it's the original system disk, just plug in Q1 and do restart. Download will start automatically.
                  Experience is the best adviser!
                  • Stanman
                    • Oct 2009
                    • 24
                    Thanks CanoNiR
                    So is that going to restore the whole drive?
                    I think there are three or four partitions on it.
