ir2200
  • bomberi
    • 107
    ir2200
    thanks for all help,some week ago i am back to continue my thread for install sst. My problem is the hd and i have adapt a toshiba hd. I have format it with the hd format and its ok. Now if I want to download the system it go well and the machin make downloading in the screen, after a mn it make error: the check sun did not match, the data may have suffered loss/damage while beeing transmitted, check the conexion between the pc and the machin. I try again and it make swithing to the ecp mode has failled. So I want help good.
  • TCA TECH
    • Mar 2009
    • 104
    Have you for matted the hard drive with the correct format tool, open up for mat tool with editor and see if your hard drive type is in there.
    Copiers are only as good as there last service
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      He claimed that the format procedure went ok,, which means the drive he used had to have been in the table of drives, or the format procedure would not have come back with an O.K. My question for him is,, did you use a NEW hard drive, or a used one? Bad sectors on a hard drive do not show up under HDFormatting, that only writes the partition table and FAT to the hard drive. sounds like a bad drive to me, or bad data from the laptop. Try reloading the system software to the laptop to test that theory.
      • bomberi
        • 107
        thank 4u, my hdd is a new( toshiba mk4026gax). I've traying to reinstall the sst and begin the way, the same error appear now i want to change a laptop to try again.
        • binks24
          • Sep 2009
          • 14
          • bomberi
            • 107
            hello! Iwait always for help;I have cange pc and the sst but always the same error is hear I think it is the system so if someone can send me I will try again.
            • bomberi
              • 107
              Please i want sst old version 1.41 if someone can send me it. My thanks
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                There was a way to workaround formattimg the non-canon approved HD with a newer version if SST.
                I'll look for the instructions but, basically you open C:\ServTool\iR2200\HDFormat\XXxxv0013\ir2200XXXX.i ft file with notepad. Get the serial # off your HDD label and add it to the .ift file.
                The instructions had specifically which # from the HDD and exactly where to add it to the .ift file, which I'll post when I find it. Or,I might even be able to find an old disc with the ver1.14 SST.
                • bnmand
                  • Sep 2008
                  • 383
                  Originally posted by D_L_P
                  There was a way to workaround formattimg the non-canon approved HD with a newer version if SST..
                  Here's the instructions. See http://www.copytechnet.com/forums/at..._not_found.pdf
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    Just for clarification, it is the model number, not the serial number on the drive.
                    • bomberi
                      • 107
                      thank you for answers. Ihav done all this ways, I have formating the hdd, now i am the step to download the system and when i begen to download there are some error when data is beeing transfered but when i take the boot to transfer it go well and the system is the first to be transfered one by one. I try at least 5 hdd and i have the same error. GOOD
                      • D_L_P
                        Self Employed
                        • Oct 2009
                        • 1196
                        I doubt 5 HD would be bad. Sounds like it might be your computer. Uninstall SST and reinstall it. Re download the 2200 system software and go from there.
                        Or if you have access try another laptop to flash that 2200.
                        • ymmtech
                          • Jun 2009
                          • 190
                          You may try alternative way, check HDD SMART status, ... analyze HDD, and/or clone a good image to HHD so to filter out problem of interface between PC and copier.
                          • bomberi
                            • 107
                            I always think about solution, so help is nessessary. Because I have 4 ir2200, 3300 with same error of hdd. I ve taking another hhd with is good and i try to download and it do the same error the system can not download but i win to format the hdd. Ithink that the system is not good. The file is 1,5 MO
                            • SCREWTAPE
                              • Aug 2025
                              Hopefully you using a parallel Cable-(Bi Centronics 1284) Or a Canon USB parallel cable. Two, the best advice so far is to uninstalled SST and try using SST v3.11 or v3.22.
