Canon IR 3220 vs CLC 1180
  • shout_print
    • Sep 2009
    • 18
    I have been offered the old CLC 1180 from my old company for a OK price and an IR3220 from someone else
    both come with RIps
    the CLC 1180 has a RIP attached to the TOP not sure of the model
    the IR 3220 has a ps-nx 3000 Fiery Rip
    We are a smart startup design company we dont do a huge volume but the files are usual large Photohop and illustrator files.
    any suggestion would be good
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Colour quality wise the CLC wins hands down...but it can be pretty high maintenance so for reliability you'd go with the IRC.
    • shout_print
      • Sep 2009
      • 18
      Thanks for the reply
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5018
        both come with RIps
        You need a technician to find out a condition of the machines.How many copies,periodically replacement parts....
        my choose is clc 1180.
        • shout_print
          • Sep 2009
          • 18
          IR 3320 has 99,000 clicks
          waiting to hear from canon on a service plan, have been advised by them
          that the 3320 is a good buy
          • serginho_vl
            • Sep 2007
            • 59
            IRC3220 vs CLC1180
            The 2 machines are pretty different:
            - through the 1180 the paper passes 4 times for a color print while through the 3220 it passes once - so the speed is much better for the 3220 (32 pages vs 11 pages)
            - media tipe - the 1180 can handle upto 209 gsm while the 3220 upto 253 gsm
            - print quality (not copy) is also in favor of the 3220 - newer machine - if you want an even better/faster rip get the CLC3220 (same machine + a Fiery RIP)
            - copy quality - it's a matter of taste, but the 1180 uses silicone oil mixed with the toner, so it "smoothes" the pixels, you also get a much glossier print and you can feel the toner on the paper - it looks pretty good; the 3220 gives a matte print compared to the other (you should see same image printed on both machines, also to make a copy on both)
            - in terms of service and supplies: the 3220 easier to maintain, most units easily changed by user, price per copy beter, while the 1180 needs service tech to change drum, developer etc.
            - as a conclusion, the 1180 not a bad machine, but the 3220 is a newer generation, faster, better print/RIP, easier to maintain
