caon ir5000 error code e061
  • hamdyyassin
    • 84
    please i have a problem with my copier ir5000
    first when i turn on the copier the error code e061-0001 pop up befor the machine becomes ready to scan.
    when i turnning off potential control the machine becomes ready to scan and the error code e061-0002 comes with the first oriignal scan.
    i try to change the laser unit and the drum unit but the problem is still.
    tahnks for help
  • goofball
    • Mar 2009
    • 18
    I suspect it could be a dirty potential sensor, bad potential contol board/sensor, or primary corona unit.
    • Kapten
      • 52
      Try this
      If i were you i would check the primary corona..
      Or Potential control system.
      Anoter easy thing could be the drum screw isnt tight.
      Or the MSW2..
      Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
      1) A solid black copy means laser is defective.
      2) A white copy means you should check the Primary corona and HVT.
      3) A good copy means you should check the Potential sensor PCB.
      If it not is one of these things you are in deep shit...
      • binks24
        • Sep 2009
        • 14
        • SCREWTAPE
          • Aug 2025
          I would replace potential control along with the circuit board.
          Last two thing left to change are the primary or DC.
          When you turned off Potential control were you able to make copy and if so, how did the copy come out?
          • waffu22
            • Jun 2009
            • 95
            just clean the primary corona
            • pengtech
              • 41
              After checking or changing the parts mentioned by the above experts ( laser, preconditioning LED, potential sensor, primary assembly & dc controller ). The last thing maybe you need to try is to check the connections, check the wires of the connector.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                And good luck...coz E061 is the error code that Canon use on their "Troubleshooting Canon Devices" course that they run for their Techs.
                I did the course and copped that error to troubleshoot...
                Screwy is correct that the first thing to do is turn off potential sensing and see if you get a good copy without error...if you do you CAN leave it running like that temporarily while you seek further info.
                • waffu22
                  • Jun 2009
                  • 95
                  This problem is now happening on me after i replace a new drum. I turn off the potential control and make a copy but when i pull out unit1 and back again it suspended.
                  • songela
                    • Mar 2008
                    • 216
                    Thank you guys, I am in similar trouble, am going to apply your ideas.
                    Regards!
                    • striker337
                      update?
                      any updates on what the fix was?
