jamming
  • srv
    • Aug 2008
    • 82
    jamming
    Hi there.I have a canon ir3035n giving intermittent jamming problems at the vertical transport section and also as the paper is exiting the fuser.The jam codes are 0108,0207.It happens from all trays.Have there been any mods for this problem?. I am also having similar jams on canon irc2880i.Any ideas would be greatly appreciated.
  • dlucas
    • Oct 2009
    • 31
    have you checked the cassette paper indicator? is it the corect paper size? if jammed at the fixing then try checking the fixing assembly may be problem at the fixing film.
    • srv
      • Aug 2008
      • 82
      Paper trays are set correctly and I have ordered a fuser but I am not convinced that it will rectify the problem.
      • 20YRSEXP
        • Oct 2008
        • 281
        Putting a wrap on the sensor arm springs on those machines have been known to help. I would wrap the ones just before and just after the fuser. I would also check the condition and operation of the flapper in the right side door assembly. Look for warping and chips or wear.
        Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5019
          How many clics you have?
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            Single sided copies or duplex, or both?
            • srv
              • Aug 2008
              • 82
              318k.
              • srv
                • Aug 2008
                • 82
                both.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Also...this machine will tell you exactly what sensor is at fault by touching the screen while you're looking at the list of jam codes in service mode...which sensor is it telling you is at fault?
                  • srv
                    • Aug 2008
                    • 82
                    I appreciate all your helps folks so I replaced the fuser and the feed section for tray 1.I also applied some draft excluder to the guide that houses the idle rollers for tray 1 just to give it a little bit more grip when feeding the paper.So far so good.Once again,thanks for your help.
                    • CanonHPTech
                      • Apr 2007
                      • 235
                      1. The Fixing Assy. (usually you have a worn film showing on edge of copies and possible intermitten dog eared copies on side of worn film)
                      2. On the Right Hand Door, when closed, sits right above the Fixing Assy. , there is a black deflector of sorts that has two little black pads underneath both ends of it. First make sure that you the deflector is moving freely. Usually the pads melt and the deflector will stick and give you a 0208 accordian jam in the Fixing Assy.
                      3. If you have the Internal Finisher S1 installed, remove the (2) black idler rollers w/springs that are in the exit path just above/after the Fixing Assy. and right before the Finisher Inlet. Don't ask me why, but there were tech pubs on this and on previous models when the Internal Finisher was installed, you would remove these puppies.
                      The C2880 is slightly different. The Fixing Assy. is very different and I believe the delivery area and deflector is different. Haven't had this jam with the color series as much. Let us know if you see the machine again (besides your nightmares).
                      The glass maybe half full, but less is more...
                      Printer + Fax + Copier = Jack Of Many Trades,
                      but Master Of None
                      Color Copier = Not A Color Printer
                      InkJet MFP = Not A Fax Machine
                      B/W Copier = Not A Press
                      Finisher = Deal Closer (salesman, not accessory)
                      Copier Tech = Admin's Stress Ball (Scapegoat)
