ir c3220 dark copy quality
  • totoro
    • 568
    Hey all,
    I just got an irc 3220 running after being in storage for awhile. I cleaned the optics and the copies were still a little lite so I ran a full gradation and the copies are really really dark now. I did a ccd adj and tried a quick gradation but the copies are still really dark. I don't have a lot of experience with these. I don't see anything in the sm that helps. the drums are only around 70 percent and nothing else is due to be changed. Anyone have any advice? TIA
    Totoro
  • dlucas
    • Oct 2009
    • 31
    try check the value under copier>adjust. refer to the value label of the machine. if this has been done then try clear dc-con. hope this help
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Originally posted by totoro
      Hey all,
      Things to try would be...
      More than one Full Auto grad...cleaning the Salt sensor...removing the drums and give them a shake.....perform a single color test chart print and see if you can isolate it to one color...lastly try a new set of drums but turn off AINR in service mode first so that you don't blow the fuses on the drum units.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5018
        you try to ccd adj.Hmm..Do you have dark copies or print too?Try to play with pg test in service mode and you are find out the problem.
        • totoro
          • 568
          Thanks for all the suggestions. Unfortunately I will not be able to get back to the machine until the last week of the month. I will update you all after I try all your advice.
          Totoro
