Interrupt key
  • Peter Sim
    • Sep 2008
    • 445
    Interrupt key
    Hai all ,i need help.Interrupt key is not functioning on Ir3300/ir3530 machine.
    When you start copying non stop 30 copies,half way thru ,when you press the interrupt key,it won't stop,the machine will continue copying untill finish.Any idea?Thanks.
  • pengtech
    • 41
    Your interrupt switch in the control panel maybe not working (corroded). You can try to apply some WD40 into the switch and press it for awhile.
    • andy21557
      Help Desk Technician
      • Jul 2009
      • 62
      interrupt
      Canon imageRUNNER models have the ability to interrupt print jobs to perform copy jobs. In order to interrupt a print job to perform a copy job, you must first set the Printing Priority so that copy jobs have priority over print jobs.
      1. Hit the Additional Functions button.
      2. Press Common Settings.
      3. Select Printing Priority.
      4. Set the priority (1, 2, or 3) for each function (Copy, Printer, Mailbox, and Other
      an interrupt job musty be done directly from the glass
      • wingnut132
        • 65
        Using the interrupt function on most newer Canons it will not stop the current job, you need to watch the screen and it will say ready for interrupt job.
        • Peter Sim
          • Sep 2008
          • 445
          After i press interrupt key, the screen show"ready to perform interrupt job"but the copying job till continue.what should do next?
          • wingnut132
            • 65
            When it says ready to perform start your interrupt job. Pay attention to when it is done as it will continue with the other job pretty soon after the interrupt job is completed
            • Peter Sim
              • Sep 2008
              • 445
              Thank you wingnut132,i will try.
