Paperjam on Imagepress C1
  • petter-sprett
    • Aug 2025
    Hi.
    After changing the transfer belt on my C1 I got the paperjam message all the time. The A3 paper stops in the fuser. In the service mode I get the jam code: 020A on A3 paper and 010B on A4 paper.
    Are there any place to het hold of the latest firmware?
    Thanks,
    Petter-
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    you have problem with sensor No ps10,but try to disconect and conect again all conectors.I have a lot problems with cables.
    • petter-sprett
      Hi.
      Do you know where the sensor are located? I don't have a service manual.
      Thanks,
      Petter
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Originally posted by petter-sprett
        Hi.
        Thanks,
        Petter
        Sooooo why the hell would you service a C1 fuser WITHOUT a service manual?
        You now have discovered the end result of servicing machines WITHOUT a manual...good work
        • zoraldinho
          • Mar 2008
          • 5015
          What kind of tech are you without service manual?Good luck!
          • petter-sprett
            Imagepress C1 Paperjam
