Canon E-Maintenance
  • Matej
    • Aug 2025
    Canon E-Maintenance
    Hello everyone. I have a problem with activation machine on e-maintenance. Some copier have successfully comunication with ugw portal and some copier is negative comunication. I tried clear and then set everything thats Canon described in service manual and our Canon portal and machine canot comunicate with ugw portal. Is everyone try and play with these e-maintenance activation? Thanks with answer and have a nice evening.
  • SCREWTAPE
    • Aug 2025
    Are you a Canon authorized dealer?
    • Matej
      If you are not Canon authorized dealer you cannot conect on ugw portal because you dont have username and password .... If you want using these application ( e-maintenance) you must sign contract with Canon and you must pay.. Yes i m Canon authorized dealer. Canon gold partner in Slovenia.
      • SCREWTAPE
        • Aug 2025
        Which machine are you trying to connect?
        • Matej
          Canon irc 2380 and ir 1021i .
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            iRc1021I?
            Color machine yes?
            Try clearing ERDS Dat....try clearing CA-KEY...switch ERDS to on and try a commtest.
            Also...make sure that proxy settings are on with a valid proxy address.
            There's a whole procedure printed out from Canon with regards to troubleshooting ERDS....
            It SHOULD be on Icon for download in Imageware.
            • Matej
              Originally posted by Oze
              iRc1021I?
              Color machine yes?
              Hi everyone. I tried all these and still not working...
              • dekoster
                • Aug 2012
                • 84
                Re: Canon E-Maintenance
                wir auch Ajruli kopiersysteme :-)
                • Jumping Jack Flash
                  • Jul 2009
                  • 66
                  Is it possible to configure Canon devices so that the counters are sent by e-mail?
