ir5570 image problem
  • mts777
    • 20
    I have a Canon ir 5570 that has almost blank copies. If the potential control is turned off they are completely blank and the image can be seen. It's the same on test prints and copies. I have swapped the potential control, dc controller and corona assemblies with no luck. Also, there is an alarm code of 32001 in the history that is not in the service manual. The meter is 550K. Any ideas?
    Matt
  • SCREWTAPE
    First instead of swapping coronas just replace them. Also if you are swapping potential control, make sure you swap the set, meaning the pcb that comes along with the potential control sensor.
    Try doing a DPC in service mode.
    What does VL1 look like in dpot?
    • mts777
      • 20
      Vl1t = 60v
      vl1m = 46v
      • mtech
        • Mar 2007
        • 307
        Screwtape is right! not only the set but the cable too. this is all calibrated at the factory. You must replace all three as one unit. I have done this before. It did take care of the problem!
        • SCREWTAPE
          Originally posted by mts777
          Vl1t = 60v
          vl1m = 46v
          Well that looks good!
          Not the laser!
          • Oze
            Ricoh Fanboy
            • 1663
            Check the rear of the Fixing feeder frame assembly where the Transfer/separation coro joins in.
            I've had a machine with EXACTLY the same symptom that you've described and the holder for trans/sep was broken.
            • CanonHPTech
              • Apr 2007
              • 235
              Well, as much as I hate to say it, you could be down to the laser, even though its not showing signs. Think I've had this before and it wasn't throwing codes and had good readings. There is also and outside chance that you have a developer problem. Make sure you have a good coat of toner on the roller. Also, back to the basics, make sure that your primary fan cover is fully seated. This engages the laser shutter. I think you get dark/black copies when it is broken/loose, but check it anyway.
              The glass maybe half full, but less is more...
              Printer + Fax + Copier = Jack Of Many Trades,
              but Master Of None
              Color Copier = Not A Color Printer
              InkJet MFP = Not A Fax Machine
              B/W Copier = Not A Press
              Finisher = Deal Closer (salesman, not accessory)
              Copier Tech = Admin's Stress Ball (Scapegoat)
              • banshee2000
                • Oct 2009
                • 11
                I would check the block on the back of the transport bed and make sure the plastic piece the trans/sep corona plugs into isn't broken. Seen this b4
                • Oze
                  Ricoh Fanboy
                  • 1663
                  So that's 2 votes for a transfer issue
                  • CanonHPTech
                    • Apr 2007
                    • 235
                    I will join that too... I have seen that transfer block broken also and copies were just about blank. However, if the block is cracked, drawer one shouldn't be able to be slid all the way in and it should have been relatively obvious that it was broken when he slid in the Transfer Corona he swapped.
                    but Master Of None
                    • mts777
                      • 20
                      Tried changing the transfer block. No luck. Swapped a laser with a working one and that didn't help. Thanks for trying. I appreciate it. If you can think of anything else let me know.
                      Matt
                      • mtech
                        • Mar 2007
                        • 307
                        Maybe a stupid question, but is the mag roller turning? Or for that matter, are the augers in the dv unit turning as well? Is the dv unit full of toner? If the augers turn, but the dv unit is not quite full, run install and watch the numbers, a full dv unit will make a quick jump down. If this happens and the unit is not full, replace the toner sensor on the dv unit. Thats all I got. good luck.
                        • Gerhard
                          • Oct 2009
                          • 99
                          Hi Matt
                          Faint or blank copies are mostly caused by caronas arching. Replace caronas. Try removing pre transfer corona and make a copy (leave it out).
                          Trick front door and phisicaly check caronas while copying. are they glowing purple (transfer).
                          Good luck
                          sigpic
                          Life is a Journey enjoy the ride !!!
