IR 5055N Jamming Left hand deck
  • Gerhard
    • Oct 2009
    • 99
    Hi Guys
    Please jump in if you can help. I ve got an IR5055n that intermittendly jam (code 0108) the left hand deck. The right hand deck works 100% I have tried fresh paper ,replacing inlet guide (Service bullitin). Too no avail. Please help!!!!
    sigpic
    Life is a Journey enjoy the ride !!!
  • andy21557
    Help Desk Technician
    • Jul 2009
    • 62
    will it duplex from the right deck without fail ?
    0108 = left deck pull off sensor ... check the p/u tires to see if they are lifting up off the top of the stack between each sheet if not it maybe the the pull off clutch in the back of the copier behind the fan duct
    CL4 ( left deck pull off clutch ). Part number FH7-5729-030. CL4 is located on the rear of the iR behind the fan duct.
    • Gerhard
      • Oct 2009
      • 99
      Thanks will give it a go tomorrow
      sigpic
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Originally posted by Gerhard
        Hi Guys
        Hi Gerhard,
        Most left hand paper drawers have a one way bearing on the input shaft, I have seen these seize up and prevent the feed operation, have also seen it be sporadic as to when it occurs. When you rebuild these assemblies, be sure to put a drop of oil on the shaft next to the bearing. This is especially true for units that have a lot of miles on them.
        • Canuck
          Tech Specialist
          • 1713
          make sure the white block is not missing from the paper deck itself. It has to be mounted during instal..it allows the sep roll to move up into position. Remove the right deck,look at left deck feed components with flashlight and open and close the left deck to make sure sep roll moves up against feed roll when the deck is closed.
          • SCREWTAPE
            • Aug 2025
            Make sure that jam stopper is screwed on as Canuck mention. There is also one other part towards the rear of that paper stock ass'y(deck). It has one screw, its sort of like that jam stopper. Also check the cable that lifts the tray inside of that deck. Manually raise it up and make sure that its coming up evenly.
            • goofball
              • Mar 2009
              • 18
              One other thing I have been replacing for intermitent jamming is the tourque limiter on the sep roller. This in many cases has cleared up problems with multiple models of copiers that are having intermitent jamming.
