E-maintenance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    E-maintenance
    Hello
    My problem is connect machines in to e-maintenance.This year i try to connect about 50 machines but 20 of them don't wont to connect.For example i try to connect two the same machines in one room,on the same network end one wont connect.Keys and certificates are the same too.
    (irc 2380).
  • Walestech
    • Aug 2009
    • 16
    Have you tried taking a network data list print, then switch on DHCP reboot and let the machine pick up all it's network settings. Reset the ip address to the original address, turn off DHCP and reboot. Check for firewall issues regarding port 443. You might need to set up port forwarding or move the ip's of the non working machines.
