Canon ir 6570
  • Brucere99
    • Oct 2009
    • 15
    Canon ir 6570
    Need network help on a canon ir 6570. I can ping the copier, but
    cannot print.
    Does it gave a 'N' bootrom?
    • Brucere99
      • Oct 2009
      • 15
      Canon ir 6570
      No, i checked the bootrom and there is no n
      • SCREWTAPE
        • Aug 2025
        You must have a printer kit installed. Check the counter button under device configuration and check to whether there is printer kit installed, UFRII, PCL should be present if not then there is no printer kit.
        • Brucere99
          • Oct 2009
          • 15
          Canon ir 6570
          Is it possible the card is in the copier, but software was not installed?
          • SCREWTAPE
            • Aug 2025
            The program is embedded into the main controller thus must be activated with a license.
            As far as I know there is no compartment where you can store this card.
            • Jehuu
              • Nov 2009
              • 6
              cannot print.
              which driver, printer language, did you use?
              what was the error code in printer job log?
              Test it with UFR2 printer language.
              as long as i can remember you could not configure network settings if the copier didn't have a printer board installed, i could be wrong.
              Jehuu
              • costd
                • Jan 2008
                • 409
                1. You never indicated if you checked the device configuration to verify IF you have the printer kit installed.
                2. Yes, you can configure network settings without it having a printer kit. The "kit" is nothing more than activating the lisc (as in everything else, hardware, is there).
                3. IF you do have the printer kit installed (and activated by lisc) then make sure you are using the right driver.
                • mrfixit51
                  Lead Service Technician
                  • Oct 2008
                  • 1975
                  To add to what Costd replied to, the newer boxes come with network capability built in, (1) for software upgrading, (2) so the the device can be managed remotely through RUI. You can do any number of things like fax address book maintenance, see whether the system is up and running, etc, etc, etc.
                  • Gerhard
                    • Oct 2009
                    • 99
                    cannot print.
                    Check if your ip range settings under network/tcpip settings are witin the scope of the users network.
                    Regards
                    sigpic
                    Life is a Journey enjoy the ride !!!
                    • Brucere99
                      • Oct 2009
                      • 15
                      Installed printer kit and I now have an N under bootrom. Im looking for the procedure
                      for installing Imagepas M3 Controller to the IR 6570.
                      • tongee
                        • Nov 2009
                        • 50
                        cannot print.
                        port not set tcp/ip
