Canon IR 400 b/b paper jamming
  • sayednabil
    • Sep 2009
    • 72
    well when i make blank copy paper come out properly when i make any printer copy it stop down the drum , i have check the regesrtration lever is fibe , i have also check the upper scanner sensor but the problem is not solve yet.
    regard
    Nabil
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Can you give a little more info?
    What jam code do you have?
    Is the paper stopping at registration and the copier just "hangs" there, or actually register a jam?
    If it's hanging you might not be waiting long enough for an E100 to show up.
    • tingps
      • Aug 2007
      • 9
      re:Canon IR 400 b/b paper jamming
      I have encountered similar problem.
      First, I would clean the Transfer roller but this rarely help.
      Most of the time it is remedied by changing the paper.
      I observed that the paper recovered from the conveyor section, had its print missing about 1 inch away from its trailing edge
      • sayednabil
        • Sep 2009
        • 72
        well i am using 80gsm paper almost same paper which i use in most of the machine
        • sayednabil
          • Sep 2009
          • 72
          [QUOTE=sayednabil;104353]copy just got hang down the drum if i make copy from cassette, if i make copy from manual select paper does not stop down the drum. and there is no error code i am getting in machine
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            Can you elaborate on this "hang down the drum"?
            "manual paper select", do you mean the manual feed tray (or by-pass, multi-feed depending on who you talk to)?
            It's rare but I have seen those separation assy go bad. Check that its in all the way or not cracked open. Or just replace the assy FG6-0456-000.
            If it's copying fine from the manual feed tray but jams from the cassette, I wouldn't focus too much on the paper path around registration.
            I'd clean the feed tires, I've seen brand new ones jam. We use RG5-1834-000 sep tires on a blue hub instead of the ones on the OEM on the white hub.
            Any more info would be appreciated.
