iR C3220: machine restarts when using "send to file" function
  • sgcopiertech
    • Jul 2025
    anybody experienced this problem?
    photocopy and printing is working fine
    but when you use the "scan to file" function
    the machine would just restart by itself.
    thanks!
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    I'd try reinstalling system software. Reseating memory fixes a lot of weird problems too. If that doesn't work then I'd replacethe HDD. Possible bad sector on the HD? Maybe just the partition used for scanning, which would let copy/print work fine.
    • sgcopiertech
      thanks! technician is on the way, i'll keep you posted.
