ir4570
  • karta
    • Oct 2009
    • 15
    ir4570
    i have a ir4570, but now e602 0001, and i don't have firmware software, if you have pls inform me to candiyanto@yahoo.co.id , i have sst 3.02 and many firmware (ir3300, ir5000 d/dn)
  • SCREWTAPE
    • Jun 2025
    Chances are you will probably still need a HDD.
    Good luck.
    • karta
      • Oct 2009
      • 15
      Good luck.
      why do i need a new hdd, because i think its running well w/o noise? pls help me
      • SCREWTAPE
        • Jun 2025
        E602-0001 is a HDD faulty code. Try scanning the HD, see if that helps first.
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          Here is why you need a new hard drive...
          Noise is not the only issue that you can face on these machines. Service Support Tool will not map around bad sectors on the hard drive. The copier is very labor intensive on the hard drive, every process requires writing to, and reading from it. So when it goes out under a 602 code,,, you had better replace the drive and reload system software. Or you will get to return later to eventually perform that task.
          • Starion
            Tech
            • Jul 2008
            • 58
            and unfortunately they dont last very long if you dont replace the hdd i've noticed..
            you could try a hdd check.. start the copier while holding 1 and 9.. might get it going for a while, but chances are you'll be back quite soon..
