Canon gp335 code e-220
  • asambatra
    • Jul 2025
    I have a code E-220 on my gp 335..
    What can i do to resolve it?
    Thank you
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Thank you
    I have to make a leap of faith on this one, the gp335 is similiar to the iR330. The scanning lamp is what is causing the issue. It does not appear to be bright enough.
    - Check for bad lamp.
    - The intensity sensor has a fault.
    - The CCD PCB has a fault.
    - The composite power supply PCB has a fault.
    - The DC controller PCB has a fault.
    • Gerhard
      • Oct 2009
      • 99
      Mrfixit is spotton !!!
      The Gp335 uses a flourecent scanning lamp. Check the end of the lamp for discolouration (black rings). If so replace !!!
      PS: its good to now the old timers are still around!!!!
      Regards
      sigpic
      Life is a Journey enjoy the ride !!!
      • alex@wocltd.com
        • 430
        you can also take a small capactior of the cpsu to prevent re-occurence
