IR C3220 Duplex Adjustment screw
  • Steltenpohl
    • Nov 2009
    • 18
    Where is the duplex adjustment screw, I have the manual, but still can not find it.
    TIA
    Jerry
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Request for info is too general in nature...
    TIA
    Jerry
    On what page in the manual is this reference made to the adjusting screw?
    Are we talking about the copier or the document feeder?
    • Steltenpohl
      • Nov 2009
      • 18
      We are printing to the 3220 .PG 2-8T of the service manual, the front and back are good comming out of the trays, but duplexing there off.
      CHAPTER 2 STANDARDS AND ADJUSTMENTS
      2-8T
      1.3.4 Duplex Unit
      F02-103-10
      [1]
      left right
      • Van Steal
        • 177
        2-8T
        1.3.4 Duplex Unit
        Loosen the adjusting screw [1] to make adjustments. (A single graduation in the index
        will cause a change of approximately 1 mm.)
        F02-103-10
        [1]
        left right
        The duplex is adjusted in service mode under adjust-feed adj-adjust refe page 5-62..Make sure your tray is setup first
        • Steltenpohl
          • Nov 2009
          • 18
          Thank You
          Thanks you very much, wonder why they show that Picture:?
          Jerrt
          • nivssluck
            • May 2008
            • 228
            If I cannot adjust through the service mode under adjust-feed adj-adjust refe, that's the time I use manual adjustment by moving the screws like the four cassettes.
