IR 5870 - Macintosh Driver?
  • byrock
    • Jul 2008
    • 13
    We have a IR 5870 we are using in a multi-office environment.
    I am not proficient in Mac's but know enough to usually get the job done.
    We have a user who has a Mac with OS X - not sure what exact version but I am not sure it matters.
    I downloaded the PPD driver - v 2.80 to his laptop and was I think I was able to get it installed correctly.
    Since we are in a multi-office environment, everyone has their own mailbox and we require an account code in order to print.
    I looked under every option I could see and did not find anywhere in the options to enter either the mailbox or the account information.
    Any clues on if I need a different driver or where exactly I should look?
  • victor_v
    • 71
    Hi,
    iR5870C/Ci
    Good luck
    Hardworking people are not present. Simply many it is boring to idle.
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      You can't change the PPD from the print center. You can manually edit the PPD if you have a text editor for your Mac. Or change the destination every time you hit file print from a program.
      File>Print>from drop-down menu hit printer features
      Choose Destination and change it to Mailbox. From that drop-down menu add the mailbox #. There should also be a place to enter the dept ID under the drop down menu.
      If you don't have the Fiery C1 controller, use the UFRII driver and it should have a place for Dept ID and mailboxes.
      • byrock
        • Jul 2008
        • 13
        Thanks, I will try the UFRII driver as we don't have the fiery controller on this machine.
        When I was looking for it originally, I had Word open, and I did hit file - print and looked under the printer features and I don't remember seeing anywhere to choose a destination or enter a code. I clicked on every drop down, and the closest I saw was a "Bill to" area but I think that was for the cover page.
        Anyways, I don't have access to the Mac now, but I will give it another try when I get the chance! Thanks!
        • SCREWTAPE
          • Aug 2025
          I believe you need this driver. UFRII_v2.00_MacOSX.zip.
          Canon U.S.A: Support
