Canon C330d Default Exposure
  • Matt25112
    • Mar 2008
    • 38
    I can see how to enter the service mode, but do not have a manual. A customer wants to change the default exposure from auto to a few knotches down. Thanks.
  • SCREWTAPE
    • Jun 2025
    • Matt25112
      • Mar 2008
      • 38
      Yea I may have to go out to the site. I figured the A (auto) they were referring to exposure...not a canon tech at all and unfamiliar with the control panel's or how to change defaults.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        They may need to have the copier calibrated because the images are coming out too dark. No magic bullet for this. On color imagerunners we have auto gradation, but on this old girl we needed to do this manually in service mode. First off the optics have to be cleaned, and this may actually resolve your problem without the adjustment, so be sure to clean it first and test it. If that does not resolve the issue, enter service mode and perform the following:
        Additional Functions
        2 & 8 together
        should be in service mode now...
        3 - Adjust mode
        DENS ADJUST
        set to 5 and press OK
        4 - Functions mode
        CCD
        CCD-ADJ
        press the OK in display panel lower right corner
        DENS
        WHITE-ME
        place at least 5 sheets white paper on scan glass and press OK
        PD-DENS
        press the copy start key
        PD-ME
        place previous generated print on glass, light bands to left side and press OK
        DZ-DENS
        DZ-ME
        The copier is now calibrated,,, this should be performed whenever copy quality calss are generated, and at drum change ...
        • Matt25112
          • Mar 2008
          • 38
          thanks!
