irc 3220
  • pontiac
    • 420
    irc 3220
    just delivered a 3220 and will not do multiple prints, installed a res board A2 and still no multiple prints. Any ideas. Thanks alot
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Reseat the memory. It's supposed to have 256MB. Any error codes or does it just lock up?
    • SCREWTAPE
      • Aug 2025
      Won't do multiple prints meaning PRINTS from a computer????
      The resolution board is a component that's usually installed with universal send; I'm a bit confuse???
      • alex@wocltd.com
        • 430
        i have had this - it turned out the previous engineer had installed the 'rip' driver instead of the correct 32xx also had on 2380/3580 when someone had installed (again!) the j1 driver - it would allow the print job job but only once if you asked for 2,3,etc it would only print one set...
        • pontiac
          • 420
          multiple prints
          Sorry guys should have put more info. Yes the problem is from printing from work station. You have to go to printer settings at copier and select how many prints you want in order to do the job, bummer is if you dont set it back to 1 next job sent is printing just as many as previous job. Hope this is helpfull. Thanks again
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            Alex had a good suggestion.
            What controller do you have, the Canon embedded or the Fiery?
            • pontiac
              • 420
              prints
              It has the embeded print.
              • pontiac
                • 420
                multiple prints
                We Replaced the copier, when we brought the other unit back to the offfice we were able to do multiple prints. Works in our office but not the customers, the replacement machine works great. Thanks for all the suggestions
