Canon IR C3200 Scan setup manual
Alan Aya
Fish- To get the credentias there are 2 ways. Look up the user/pass on you active directory server, or export the address book to a file and get it from there.
To export address book to file: Open web browser and type in copiers IP address. Click on Additional Functions -> Import/Export -> Address Book -> Export. Assuming the working entries are in book 01, leave it at Custom Format and click Start Export. Save the file and open it with Notepad, Or Firefox will work too. There you should see the user name and pwd the copier is using to get into the shared folders. I've never tried it but I suppose you could add entries following the format to the file then import it.
To add from copier, Additional Functions-> Address Book Settings-> Register new address-> Add new entry. Browse with SMB, or manual entry. Host can be PC's name or IP (\\192.168.0.xxx), path is just \share. But it is much easier adding new entries with the RUI.
Alan- http://www.copytechnet.com/forums/at...mac_10.6.2.pdf This was just recently posted in the connectivity forum.
Thanks again guys.Comment
Alan Aya
BTW where can i download the fax driver (iR2270) for MAC? Have tried the Canon USA site, couldn't find.
ThanksComment
Here are some links for a MAC fax driver:
Mac Fax v1.60
MAc Fax v1.62
Note that this driver is not supported on Mac OS X 10.6 (Snow Leopard)Comment
Alan Aya
Mac Fax v1.60
MAc Fax v1.62
Thanks again for your help.
Alan AyaComment
Hi D_L_P, thanks for the Fax Driver link, it has been a great help to me. Do you mean that these 2 drivers are different? i did manage to download the MAC Fax v1.60 from Canon Europe site yesterday morning and tried to install it but without success. Do we need to find out what OS the customer is currently using to decide which to use? Please correct me if i am wrong.
Alan Aya
Supports> 3200/3220/2620
Fax Driver v1.62 for Macintosh OS X
Fax Driver v1.62 for Macintosh OS X supports the Power PC: Mac OS X v10.3.9 to 10.5 & Intel: Mac OS X v10.4.4 to 10.5. This driver adds support for Mac OS X 10.5 (Leopard). (Does not support imageRUNNER 2018/2022/2025/2030/C5058/C5068, Color imageRUNNER C2550) "
imageRUNNER and Color imageRUNNER Fax v1.60 for Macintosh OSX
imageRUNNER and Color imageRUNNER Fax v1.60 for Macintosh OSX. New Support for iR C5180/4080/4580 (System Ver. 50 or later), iR C2880/C3380 (System Ver. 60 or later), iR5075, iR5055/5065, iR3025, iR3030, iR3035/3045, iR C5185-H1, iR C5180/C4080/C4580-H1 (Sstem Ver. 50 or later), iR5075-S2, IR5055/5065-S2, MF4600 Series.
http://www.usa.canon.com/opd/control...9&modelid=8927**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
lorihajost
Re: Canon IR C3200 Scan setup manual
Alan- http://www.copytechnet.com/forums/at...mac_10.6.2.pdf This was just recently posted in the connectivity forum.Comment
